LOGERIAI
Ultra lengvų orlaivių Federacijos Reikalai
Darius
Pranešimai: 444
Užsiregistravo: 12 Gru 2005, 16:48
Standartinė Darius » 03 Lie 2008, 15:17
Kalbejau su broliu Ryciu Buzeliu (profesorium vadinamas) Saulius turi zinoti.Balionistu logeriai neatitinka mums iskeltu reikalavimu.Kazkodel mums butinai reikalingas barometrinis slegio matuoklis ko nereikia balionistams ir dar ten kazkas netinka.Siaip jiems ir uzpakuotas gps'as tinka,pakabintas baliono virsuje..
Senas,patyres kamikadzė
Standartinė Reno » 05 Lie 2008, 16:49
Dideja tikimybe, kad 2008 m Europos PPG cempionato metu logeriu problema pavyks sekmingai isspresti - MLR atstovai pazadejo atvykti i varzybas su savo iranga. Vieno prietaiso nuomos kaina - 50 Eur.
Visiems Lietuvos rinktines nariams LABAI PATARTINA pasiimti ir savo GPS. Juos naudosime kaip dubliuojancia iranga. Jeigu del kokios nors priezasties skrydzio metu MLR pavestu, atsarginis GPS (zinoma, teiseju uzantspauduotas, kad skrydzio metu nebutu galima stebeti jo rodmenis) liks vienintele priemone, issaugojusia skrydzio duomenis. Be abejo, su savimi reikes tureti laida pajungimui prie kompiuterio ir atitinkama programine iranga.
Standartinė Ai varom » 06 Lie 2008, 18:56
Puiki zinia!
Standartinė Reno » 15 Bal 2009, 12:00
Atrodo, kad is mirties tasko pagaliau "pajudejo" logeriu klausimas. Kaip zadejo siu metu Pasaulio PPG cempionato direktorius Richard Meredith-Hardy (...there is still one big outstanding problem which is the shortage of GPS flight recorders. There are only two types currently approved by CIMA, the MLR, which is no longer available, and the Air Observer from South Africa. It is not unusual for one third of competitors to come to a championships without a flight recorder, but this year it seems very unlikely there will be any available on loan, so pilots will have to come with their own flight recorders, or not get a score. You will be pleased to hear that I think there is a solution; I have been testing several types of new and very reasonably priced GPS loggers and they look very promising. I am confident that a reasonable time in advance of the championships the CIMA Flight Recorder Approval Committee will be able to authorize their use at WMC and WPC 2009.) dar siemet iki varzybu CIMA'oje gali buti iteisintas naujas nebrangus logeris, tinkantis bet kurio rango ULO cempionatams.
Prietaiso kainos suzinoti dar nepavyko, taciau pradine informacija apie logeri AMOD 3080 galima rasti cia:
www.flymicro.com/frdl
http://www.flymicro.com/frdl/index.cfm? ... 080%2Ehtml
Prancuziski MLR jau paseno ir daugiau nebegaminami. PAR logeriu Air Observer Mini ir Micro dauguma, matyt, nepageidauja del santykinai dideles kainos. Todel ir siekiama iteisinti prietaisa, kuri galetu isigyti kievienas varzybose dalyvaujantis pilotas, nes nuo siu metu issinuomoti logeri varzyboms galimybiu jau nebebus.
Pranešimai: 5227
Standartinė Ricardas » 15 Bal 2009, 15:00
Amod AGL3080 GPS Data Logger
Ebayjui 65$ kainuoja , apie 170 lt.
http://cgi.ebay.com/Amod-AGL3080-GPS-Da ... 7C294%3A50
Standartinė Ai varom » 25 Bir 2009, 08:27
Kam reikalingi loggeriai:
Dear Aivaras
Right now I am in Czech Republic making their National championships.
I am out of stock of AMODs, but I will definitely have some more before WPC.
I will tell you when I have them and I can either send it to you in Lithuania or you can collect it when you arrive at WPC.
Cost including VAT is GBP 68.94 which is about EUR 81, + postage.
If you can send me a VAT number then I can invoice you without VAT under the EU reverse charge rules.
Regards
Richard
Standartinė Reno » 25 Bir 2009, 09:47
Akivaizdu, kad 2009m WPC direktorius Richard Meredith-Hardy savo pazada del pigesniu logeriu istesejo - AMOD'a galima naudoti tarptautinese varzybose, tiesa, dar tik laikinai. Taciau pasitvirtinus sio logerio patikimumui CIMA jis iteisins galutinai. Pirmieji bandymai rodo, kad jis vekia patikimiau uz vos ne triskart brangesni prancuziska MRL.
